1966 Ford Mustang
REECEMAC
Engine Mechanical problem
1966 Ford Mustang V8 Two Wheel Drive Automatic
#2,6,7 cylinders are not firing ,brand new 289,edelbrock performer pakadge kit on fresh block.hydrolic lifters,and cam roller tip rockers,aluminium edelbrock heads.not in exaust strock .i think lose rocker maybe
Aug 15, 2008 at 4:23 PM
  • 31,937 POSTS
Hi there,
the first thing to do is a compression test, if you suspect a valve problem take off the rocker covers and do a valve lift test with a dial indicator, this will show and variation in valve lift.
mark (mhpautos)
Aug 15, 2008 at 10:21 PM
REECEMAC
did compression test #2and 6 nothing #7 has 150
Aug 16, 2008 at 4:03 PM
  • 31,937 POSTS
Hi there, check the inlet valve lift and if that is ok, your problem is fuel Or ignition related, get a run on an oscilloscope to check all the ignition electric this will show up any individual cylinder faults, do this next.
mark (mhpautos)
Aug 16, 2008 at 4:33 PM
