Engine Cooling problem
1965 Ford Mustang 6 cyl Two Wheel Drive Automatic
How do you remove and replace the fan, fan blade spacer, fan clutch and water pump? I removed the radiator and fan blades but cannot remover the fan blade spacer and fan drive clutch and housing to get to the water pump. Thank YOU!
Mar 21, 2010 at 2:33 PM
