1965 Ford Mustang stalling
13,800 MILES • V8 • 2WD • AUTOMATIC
STEVECOULTON
Hi I have a problem with stalling at idle when in gear after engine has warmed up. Have rebuilt carb and all new electricals , timing set and vacuum lines as well. Car will stall during a stop while in drive, is ok if I put it in neutral. Otherwise drives and shifts fine when cruising.Any suggestions? It will sit in park and idle fine.
Sep 8, 2008 at 4:30 AM
  • 75,988 POSTS
Check the fuel pump pressure if okay-Re-adjust the air/fuel mixture and curb idle
Sep 8, 2008 at 8:19 AM
