1965 Ford Mustang Need to change shocks front and rear
BUDMOCHA
Suspension problem
1965 Ford Mustang V8 Two Wheel Drive Automatic 58K miles
I have the shocks now I need a step by step process to do this right. Can you help me? Also I need to replace the gas tank and need to know how to do that. I have the new tank and sender.
Thank you,
Jan 14, 2009 at 11:40 AM
  • 110,248 POSTS
Joe,
Both jobs are very straight forward. There will be two steel straps holding the old fuel tank in place. Remove them, remove the tank and sending unit, and reverse to replace.
As far as the shocks, two bolts hold them on. Just remove the bolts, remove the old shocks and replace them with the new ones.
Jan 15, 2009 at 2:42 AM
BUDMOCHA
Joe, this is a 65 Mustang and I don't see any straps. The tank appears to be sitting in the truck so just remove the bolts, disconnect the filler hose and sender and lift out I think.
Jan 15, 2009 at 3:50 AM
  • 110,248 POSTS
Is there any way you can take a picture of it and upload it to me?
Jan 15, 2009 at 5:16 AM
