1965 Ford Mustang Brakes to the floor
93,587 MILES • V8 • 2WD • AUTOMATIC
MY64STANG
I was driving on a country road and my brake pedal went to the floor. I had to pump the brake everytime I had to stop or slow down. What would cause this and what should I do to fix the problem?
I have drums all around.
Apr 13, 2008 at 1:19 PM
SERVICE WRITER
  • 9,123 POSTS
IF the brake fluid is low, there is leak that needs to be found.
IF the reservior is full, the seal on the inside of the master cylinder is probably leaking...meaning you need a new master cylinder.
Apr 13, 2008 at 1:29 PM
