1965 Ford Mustang
41,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARKEFARLEY
immediately stalls when put into gear. new fuel pump, carburetor, plugs, points, cap, rotor, ground wire. problem persists. neutral safety switch is good also.
Jul 18, 2008 at 11:52 AM
MERLIN2021
  • 17,250 POSTS
Check the neutral saftey switch on the tranny, use a wire and jump across the leads, if it works change the switch.
Jul 18, 2008 at 12:01 PM
