1965 Ford Fairlane clutch problem
JOHNW
  • 1965 FORD MUSTANG
My car has a 289 with 2barrel carb and 3 speed column shifter.moving from a stop the car shakes violently as i let out the clutch pedal.once i get it moving i can shift gears with a little bit of vibration.the clutch pedal seems easier to push than before.also, can i put mustang parts in my car?fairlane parts not available.thanks
http://www.2carpros.com/forum/automotive_pictures/79276_warsaw_073_1.jpg
Wednesday, June 13th, 2007 AT 8:46 AM
INDYUKE
  • 416 POSTS
Nice view. You should be able to put mustang parts into your fairlane. There will be minor differences, but probably not a lot when it comes to clutch and pressure plate.
It sounds like your clutch is "chattering". It's either severely worn out or contaminated with oil. The best repair would be to have the pressure plate resurfaced and the clutch plate and pilot bearing replaced. Those are the things that need to be done (minimum) for a clutch job.
Other things to replace are are the throwout bearing, transmission shaft seal, rear main seal, and if you really want to do a heck of a job, replace the two freeze plugs on the rear of the engine as well.
Wednesday, June 13th, 2007 AT 11:00 PM
