2004 Ford Mondeo DIAGNOSTIC CODE
2004 FORD MONDEO
JONTHAN JOSE
Engine Mechanical problem
2004 Ford Mondeo 6 cyl All Wheel Drive Manual 45.000 miles
I HAVE A DIAGNOSTIC TOOL, AND A CODE 1150 AND 1151? MY ENGINE LIGHT COMES ON YELLOW. NO ONE CAN TELL WHAT THE PROBLEM IS WITH MY FORD MONDEOST220? HELP!!!!
Mar 29, 2009 at 9:32 PM
Heated oxygen sensor/s
P1150/1151 OBD Trouble Code
Technical DescriptionLack of HO2S-21 Switch, Sensor Indicates Lean
What does that mean?A Heated Exhaust Oxygen (HO2S) sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
SymptomsYou will likely not notice any drivability problems.
CausesA code P1151 may mean that one or more of the following has happened:
Electrical:
Short to VPWR in the harness or HO2S
Water in the harness connector
Open/shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system:
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam Timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
Mar 29, 2009 at 10:08 PM
