2001 Ford Mondeo no air flow
64,000 MILES • 6 CYL • 2WD • MANUAL
TOPONE
Yesterday a small rubber tube broke in 2 at the front of the engine. This rubber tube is about 8 inches long and half an inch thick. I have replaced this piece of rubber but the car is very slow and noisy when driving slow up to 3rd gear. When you are driving in gears 4 and 5 its not as bad but still feels sluggish as if its mising something. I also have no air coming from the heaters nothing at all I have check all the fuses and they are all fine. The engine light stays on but flashes sometimes. A friend of mine done a test to see if it was the air flow to the engine but it seems ok.
Jun 14, 2010 at 6:50 AM
DAVE H
  • 13,383 POSTS
have the car plugged into a diagnsotic computer to retrieve the fault codes and repost with full fault codes for more assistance
Jul 20, 2010 at 8:30 PM
