car feels sluggish
83,000 MILES • 4 CYL • 2WD • MANUAL
JIMMYDUTT
Hi I have a ford mondeo 2001 ghia tddi. It feels very heavy and sluggish. when I opened the oil cap from the engine there's a kind of smoke coming out. I don't know may its coz of hot engine oil. If u know the solution please let me know.
Apr 11, 2009 at 1:04 AM
SQM
  • 6,383 POSTS
Low power output can be several contributing factors.
It could be as simple as a clogged air filter, which will restrict airflow into the engine and that will lead to sluggish acceleration.
This can be also due to worn mas air flow sensor or a weak fuel pump.
Having a plugged catalytic converter can also cause slugging power.
Here is a helpful guide that covers the typical lower power reasons:
https://www.2carpros.com/articles/engine-has-low-power-output
Many times, engine tune up can help restore the performance. Like changing the air filter, fuel filter, plugs, clean out throttle body etc.
Nov 18, 2021 at 6:37 AM
