2001 Ford Mondeo Camshaft
2001 FORD MONDEO
168,000 MILES • 4 CYL • 2WD • MANUAL
STU1
Hi Folks,
I live in the UK and drive a 2001, Ford Mondeo Zetec 2000cc mk2
Suddenly heard a loud-ish ticking/knocking noise from up around the camshaft area, left hand side next to belts that would occurr in bursts of 3 or 4 clicks at a time with every turn of the enjine.
My friend told me a few days later it was the oil not getting enough pressure to feed all the cams and suggested i reve it hard to try and solve the problem and, after doing this, the noise dissapeared, permenantly.
However, i must have damaged the camshaft/follower by using the car for a few days with thie problem occurring as i now lose a lot of mph when going up a hill and the acceleration in the lower rev range is not nearly as good as it was...have also noticed the torque kicks in around normal if i rev it by 4000rpm.
What do i have to do to repair the top end/cam follower?
Thanks for your time,
Stu
Mar 6, 2009 at 10:13 PM
DAVE H
  • 13,384 POSTS
you will need to verify where the actual fault lies before we can assist on repair !! your local library or autoparts strore will be able to supply a repair manual for the vehicle with step by step instructions on removal and refitting of parts !!
Mar 17, 2009 at 4:13 AM
