My car has started to burn oil quite badley. Is there a temp for of any kind for this problem. Please help
Thanks
John
Jul 9, 2009 at 7:56 PM
✓Experienced Mechanic
HI there,
What grade oil are you using and is it mineral or synthetic ?
mark (mhpautos)
Jul 9, 2009 at 9:36 PM
BONZO1
MEMBER
Not sure I have been putting heavy duty oil for engins with milage over 70000 miles I must admid it seems to have got worse since I started using this oil
Jul 9, 2009 at 10:34 PM
Hi there,
change the oil & filter and use a good quality engine oil flush, re fill with 20W-50, NOT SYNTHETIC and see how you go.
Mark (mhpautos)
Jul 9, 2009 at 10:45 PM
BONZO1
MEMBER
Thanks Mark.
I will give that a go. But what do you think I need to do about burning the oil Is changing the valve seals the best option or a new engine what do you think
Thanks again John
Jul 10, 2009 at 12:02 AM
Hi John,
This may be a case of wrong oil for the condition of your engine, i would do the oil change and see how you go over the next few weeks, drop me a line here with your consumption / smoking results and we will then look at your best options.
