2000 Ford Mondeo front and rear brake pipes corroded.
CAZ.CROSS
Brakes problem
2000 Ford Mondeo 4 cyl Two Wheel Drive Manual 130k miles
on my last advisory i was told the front and rear both sides brake pipes are slightly corroded. steering column top bearing slightly worn.
will this be expensive to sort?
thanks
Feb 26, 2010 at 9:09 PM
BLACKOP555
  • 10,386 POSTS
brake line repair wont be too bad at all but that upper bearing might cost a bit in labor dependent on their rates. a litte corrosion on the brake lines are not bad as long as they are not rusted.
Feb 27, 2010 at 2:05 AM
