1999 Ford Mondeo Rear door central locking solenoid (UK mod
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
LITES
The rear door lock will only work manually from inside.
How do I replace the locking mechanism and or the solenoid
Apr 27, 2009 at 2:52 AM
DAVE H
  • 13,383 POSTS
Remove door trim panel and watershield. Remove door lock actuator retaining nut. Disconnect door lock actuator connector. Disengage link from door latch. Remove door lock actuator. To install, reverse removal procedure.
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_600.png
Apr 28, 2009 at 8:30 AM
LITES
[quote="Dave H"]Remove door trim panel and watershield. Remove door lock actuator retaining nut. Disconnect door lock actuator connector. Disengage link from door latch. Remove door lock actuator. To install, reverse removal procedure.
Hi Dave,
Thanks for the info. I take it that it's best to replace the whole unit and not try any sort of repair.
Cheers,
lites
Apr 28, 2009 at 11:04 AM
DAVE H
  • 13,383 POSTS
The part is generally not serviceable .. you could try lubricating it to see if it just jammed up !!
Apr 28, 2009 at 10:53 PM
