1999 Ford Mondeo excessive white smoke and juddering
1999 FORD MONDEO
CLAIREBARNETT
Engine Mechanical problem
1999 Ford Mondeo 4 cyl Two Wheel Drive Manual
hi my mondeo td has white smoke coming out of exhaust and occasionally whilst driving it judders as thou it has lost power for a second then got it back. causes?
i have changed the fuel filter and this has not helped
Jul 1, 2010 at 10:48 PM
White smoke out of the exhaust is an indication of coolant burning in the cylinders-are you overheating?
Jul 1, 2010 at 11:01 PM
CLAIREBARNETT
no car not overheating, temp guage on about 1/3. oil is fine, not milky and so is water
Jul 1, 2010 at 11:38 PM
Check the oil if its mixed with gasoline-also check if you have a vacuum modulator on the transmission if so check the vacuum hose for transmission fluid and also the brake vacuum hose
Jul 2, 2010 at 8:06 AM
