1998 Ford Mondeo accelerate
100,000 MILES • 6 CYL • FWD • MANUAL
ANTHONY MURPHY
when i accelerate the car shudders like there is a blockeage some where what could this be
Jun 10, 2010 at 2:09 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 10, 2010 at 3:51 PM
