1997 Ford Mondeo Turn key starter motor turns belt but car
122,467 MILES • 4 CYL • FWD • MANUAL
ADAMSKI5882
My 1997 mk2 2.0l si mondeo has been of the road for some time, i have been turning the engine over every now and agian but couldnt take it out as it had no interior.......
I took it out for the first time in a while and it seemed to be reving at a very low stage and was slightly judery, but seemed to be getting better maybe because the fresh petrol was getting to the engine??
When i got onto the main road i put my foot down a little to try and kick it into life but may have broke it.
Now the probelm i have is that it wont start battery is fine spark plugs are good and there is fuel getting to the engine i have cheked all wires and they seem fine.
When i turn the key i presume its the starter motor that turns the belt to crank the engine, this just turns and makes a slight grinding/whirling noise but the engine doesnt start. I have put the car in gear and turned the key when i do this and let the break go the car moves but only on the power of the starter motor i think. It also wont bump start.
Please please please help........... Thanks.............
Jul 10, 2010 at 10:38 AM
  • 75,988 POSTS
If its cranking over and will not start do below to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard
Jul 10, 2010 at 12:03 PM
