1997 Ford Mondeo eNGINE MISSES ON IDLE BOTH WHEN COLD AND H
1997 FORD MONDEO
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
VIJENDRA KUMAR
MY ENGINE IS MISSING WHEN COLD AND HOT.ON IDLE AND WHEN YOU PRESS THE ACCERATOR MISS TOO AFTER 4000RPM.
I HAVE CHANGED THESES THINGS
HEAD GASKET
AIR FLOW METER
PLUSE AIR SOLENOID
HT WIRES
POWER STEERING WITH
Aug 30, 2009 at 2:55 PM
DAVE H
  • 13,384 POSTS
check cylinder compression .. replace the spark plugs and coil pack
Aug 30, 2009 at 3:01 PM
VIJENDRA KUMAR
I have changed thspark plugs and did compression test.Its 130-150 psi
Aug 30, 2009 at 3:06 PM
DAVE H
  • 13,384 POSTS
with the engine running .. remoeve the wiring connectors to the injectors one at a time ... everytime you remove one of the connectors the engine tone should change (it should start to die and miss) if this does not happen on one or more injectors they are bad and need replacing .. also make sure you are actually getting a spark at each plug !!
Aug 30, 2009 at 10:03 PM
