1996 Ford Mondeo water leak
1996 FORD MONDEO
202,237 MILES • 4 CYL • 2WD • MANUAL
STEVEH21066
hi ive recentley had a cam belt and waterpump fitted but every 3 or 4 days i lose about a pint of water ,i check the water level every and it does not move as the leak is not constant
,when it does leak there is a pool of water under my car but i cant see where it comes from,like i say this leak only comes every 3 or4 days it can happen wether the engine is running or has bin running,i do about a 100 miles aday and the temp seems to stay ok,hope you san help thanks
Nov 23, 2009 at 3:16 AM
  • 31,937 POSTS
Hi there,
You will need to have the cooling system pressure tested hot, tis will locate any external coolant leaks.
Mark (mhpautos)
Nov 23, 2009 at 9:26 AM
