1996 Ford Mondeo head Bolt torque
SHAWZER
  • 1996 FORD MONDEO
Engine Mechanical problem
1996 Ford Mondeo 4 cyl Front Wheel Drive Manual
got the head skimmed and pressure tested 1000 miles
ago and was just wondering if you could give me the torque measurements and the sequence it is done please
Monday, October 26th, 2009 AT 7:01 AM
  • 31,937 POSTS
Hi there.
These engines use torque to yield head bolts and can't be re torqued, in fact if you do you will over stretch the bolt and loose the torque efficiency, there is no requirement to re torque as with older style head bolts.
Mark (mhpautos)
Monday, October 26th, 2009 AT 7:22 AM
