1995 Ford Mondeo How to change transmission fluid
LAB82
Transmission problem
1995 Ford Mondeo Two Wheel Drive Automatic
The transmission fluid is light brown rather than cherry red and I have no idea how to change it. The car is an automatic and i've only ever had manuals
Jun 24, 2010 at 11:21 PM
DAVE H
  • 13,383 POSTS
There are drain and refill plugs on the side of the transmission .. this can be a tricky repair if never done before .. also sounds like you have burned fluid and changeing the trans fluid could do more damage than good ?
Jul 20, 2010 at 8:33 PM
