1995 Ford Mondeo Breaks quit working, also engine stalls.
100,000 MILES • 4 CYL • FWD • AUTOMATIC
AFTERSHOCKZAP
The Breaks are ABS if that helps!
Sorry if this is a bit of a rant but, recently my engine has begun stalling on start-up. It is winter over here (I'm an air force member serving in England) It has only stalled twice while in use, both times I was dropping off a fellow airmen at the dorms, drove off after sitting for a min. and it stalled at the next stop sign. That was the only issue untill friday, friday at the same stop sign my breaks had gotten really stiff and I had the break pedal fully to the floor (as far as it would let me) when I continued rolling foward. I had to pull the e-break just to get the car to stop. I then drove directly to a car care center which assured me they could look at my car the following day. They did not and now I'm stranded without a car wondering what the hell could be going on. I'm a bit freaked because I have a pregnate wife and really, truly cannot afford an expensive car bill.
In the air-force I repair Jet Engines so if the issue is something that requires removal and replacement of parts with regular hand tools I can do it myself but I have no idea what would cause all these issues, other than the breaks and the stall my car is completely fine.
Feb 20, 2010 at 9:03 PM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much apprecated
Have the crankshaft position sensor replaced .. check for leaking brake lines or a bad brake booster !
Feb 22, 2010 at 12:50 AM
