2002 Ford Maverick Bonnet latch
67,000 MILES • 4 CYL • 4WD • AUTOMATIC
CONDICT1
I have been trying to open my bonnet. I never had a problem before. The book states that you pull the
lever on the inside to lift bonnet just enough to put your hand in to lift the latch in the centre. The problem is that I cannot move the latch and wonder what the problem could be!
Sep 15, 2009 at 2:28 AM
DANAUTHIER
  • 156 POSTS
Best guess is the latch is rusted and not working freely. Try having someone assist you by pressing down with their hands on the front of the bonnet while you pull on the handle. You assistant may even have to push & let up (pump) on the front of the bonnet while you pull and release the handle several times to get the latch to come free. This may take consideral effort to pull the handle, just be carefull not to excert enough force that you break the handle.
Once you get the latch to release, lubricate the latch and cable with a good quality penertating oil.
Let me know if this helps.
Dan
Sep 15, 2009 at 2:51 AM
