1994 Ford Maverick fuel pump
120,000 MILES • 4 CYL • 4WD • MANUAL
JAYDUANE
i have 1994 ford maverick 4x4 small suv. my truck cranks when i try to start but will not start up. battery is good, my guess is fuel pump or fuel line clogged. but where is the fuel pump located on this vehicle, i cant find any info for this vehicle online. thank you for you time
Dec 5, 2008 at 8:42 PM
DAVE H
  • 13,383 POSTS
most fuel pumps these day's are located inside the fuel tank ?? i have no listing for a maverick ? could you supply the vin # do you have MIL showing on dash display ..have you checked fuse and relay .. have you checked if your getting fuel ?? sit in the vehicle .. make sure everything is truned off ..ie. radio,blowers etc. turn the key to on ..dash light's on ..do not crank over .. whith key in on position you should hear a slight buzzz noise for 10 seconds .. do this a couple of times ..see if you hear it .. if you hear it the pump is working ... let me know
Dec 5, 2008 at 9:31 PM
