1987 Ford LTD timing gear
12,500 MILES • V8 • 2WD • AUTOMATIC
PAUL_J54
Is the timing gear on this model all steel or are the gear teeth made out of nylon.
My car isn't running too good and I suspect that it could be a timing problem.
Any suggestions would be helpful as I'm sure that this problem has been around for a while with this model.
It has the first generation computer as this was the first year or fuel injection for this model.
Aug 23, 2008 at 1:50 AM
BMRFIXIT
  • 19,053 POSTS
I would start by checking tune up and ignition wires
check distributor gear
place crank shaft at TDC and check the rotor in the distributor
Sep 2, 2008 at 2:33 PM
