1987 Ford LTD Engine swap
120,000 MILES • V8 • 2WD • AUTOMATIC
BLAPER4876
can i swap my stock 302 for a 351 with out changing the mounts or the rest of the front of my 1987 LTD Crown Vic? I plan on replacing the Tranny at the same time so the sam question aplys to it as well....Thanks
Nov 24, 2008 at 9:41 AM
HMAC300
  • 48,601 POSTS
it should be a bolt in swap although i'm not sure if the 351 is balanced the same as a 302, it's been a long time. If it is then you won't have to change torque converters/flywheels, etc.
Apr 28, 2010 at 10:58 AM
