1985 Ford LTD Starting
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
CRIPNIGGAZ
I have a ford ltd.
one day i was driving it and the car just shut down
as i was driving.
the car now cranks up but wont turn over.
i dont know whats wrong.
Jan 20, 2009 at 1:23 PM
OBXAUTOMEDIC
  • 3,716 POSTS
[quote:1e892f064c="CripNiggaz"]Engine Performance problem
1985 Ford LTD 4 cyl Two Wheel Drive Automatic 250000 miles
I have a ford ltd.
as i was driving.
i dont know whats wrong.[/quote:1e892f064c]
Here are thing to check for to begin with...
1) Check for Spark at the Plugs
2) If None Check for Spark at the Cap
3) if have spark at cap remove cap and check for carbon tracking , corroded tips or a crack. If tips corroded clean and also clean end of rotor button. replace cap and try starting if vehicle starts replace cap and rotor.
If above all checks out.....
Check for fuel....
If fuel injected listen for fuel pump when turn key to on position should run for about 2 seconds. If hear pump check fuel pressure.
If carboratated take breather off while looking into carb slowly open throttle and look for fuel spraying.
Post findings here....
Jan 20, 2009 at 1:39 PM
