1985 Ford LTD
1985 FORD LTD
YUKAMHON
My LTD has a V6 engine. When I press on my brake pedal at traffic ligh stop, my check engine light comes on, and the engine runs rough and tends to die. However, when I press on the accelerator pedal, and the check engine light will go off and stays off throughout the highway speed. I adjusted the fast idle speed up some, and the engine run smoother at the traffic stop, and do not die out, but the check engine light still comes on until I accelerate, then it will go off again. I took it to the neighborhood tune up shop, and they told me I need to run a diagonostic test and brake diagonostic both to find out, and it will cost close to $150. Do I really need to run these tests to find out, or :P :P some of you have this experience and had it fixed. Thanks for your advices.
Stephen
Oct 15, 2007 at 12:27 PM
BMRFIXIT
  • 19,053 POSTS
Hi Stephen
Ok how about you do this
Disconnect the vacuum line at the brake booster
Plug it (vacuum line)
Put something in front the tires
E brake on
Start car (your brake paddle will be very hard and its difficult to stop the car so be careful to secure the car in place) put in drive and test to see if the check engine light come on or if the rpm drop
You may need a brake booster
BE SAFE
good luck
Oct 15, 2007 at 5:46 PM
BMRFIXIT
  • 19,053 POSTS
[quote:c5fbc81845="BMRFIXIT"]Hi Stephen
E brake on
Start car (your brake paddle will be very hard and its difficult to stop the car so be careful to secure the car in place) put in drive and test to see if the check engine light come on or if the rpm drop when you brake.
BE SAFE
good luck[/quote:c5fbc81845]
Oct 15, 2007 at 5:47 PM
