Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Laser
Engine
Symptoms
Hard to Start
2001 Ford Laser Rough start up
2001 FORD LASER
74,000 MILES • 4 CYL • 2WD • AUTOMATIC
VASEA
MEMBER
1 POST
Runs very rough when starting and lucks in power like its missing a cylinder or something, every now and then.
Cheers
Jul 3, 2010 at 6:56 PM
Experienced Mechanic
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 3, 2010 at 11:32 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
