1975 Ford Granada Low rpm issue
623 MILES • V8 • 2WD • AUTOMATIC
SIXX138
This Granada ghia has a rebuilt 302 v8 with only 620 some miles. The 2 barrel carb I have is a reman motocraft. The car is acting like the air fuel mix is rig for low rpms, but I hecked the plugs and they look beautiful. All carb bolts and manifold bolts are tight and no visible vaccum leaks
There is a stutter to the engine when driving at about 2 grand, and after ruleing out the coil and wires, I am at a loss.
What could possibly be causing this?
Sep 22, 2010 at 1:11 PM
  • 75,988 POSTS
Check the ignition timing , adjust the curb idle speed and test the distributor pick-up coil
Sep 22, 2010 at 1:52 PM
