2002 Ford Galaxie
MRS WOODS
2002 Ford Galaxie
hi there the problem i am haveing with my car is that when i drive the car and i try to go faster i have'nt got any power there to go fast so i am only going 20 mph when i want to go 40 or more.
Apr 1, 2010 at 8:30 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 1, 2010 at 9:17 AM
