1967 Ford Galaxie
1967 FORD GALAXIE
GOATBOY
Engine Mechanical problem
1967 Ford Galaxie V8 Two Wheel Drive Automatic 140.00 miles
NEED TO REPLACE REAR MAIN SEAL AND MOTOR MOUNTS
Sep 18, 2010 at 9:02 AM
HMAC300
  • 48,601 POSTS
you'll need a tool what they call a chinese bandit. the seal is rope. the bandit gets teh rope and pulls it out. when you change it put silicone on the edges so it won't leak you'll probably have to jack the motor up to get eh pan off and the crank will have to be in a good position to get the pan off. after all that crap just unbolt the motor mounts and replace them.....
Oct 23, 2010 at 11:59 AM
