1966 Ford Galaxie REMOVAL OF SMOG PUMP
98,000 MILES • V8 • AWD • AUTOMATIC
CJEFFREYS
I just bought this Galaxie. It has a 390 in it, though the VIN #'s say it should be a 351. The 390 has a smog pump on it & I am wondering if I can just remove the smog pump & plug the air lines that go into the head?
Also on the shift indicator on the console, there is a circle then a green circle for drive, is one drive & the other one over drive?
May 23, 2010 at 3:24 AM
HMAC300
  • 48,601 POSTS
yes to your question. you can also make that 390 a 410 easily or larger.....
Jun 19, 2010 at 1:54 AM
