Well then you are in luck a 390 with a C6 is a 390 with a C6. So this will be like pulling the original and rebuilding it and putting it back. Everything will line up just fine and the only parts you will need is if you want to do a tune up or an oil change or something like that. You will need some more anti freeze and have a quart of type F trans fluid as you will loose some when you pull the trans out unless you put a plug in the back of it. The only thing to check is at the back of the trans where the driveline goes in, make sure it is a slip in yoke for a slip in yoke, other then that all will be fine.
Thursday, October 1st, 2009 AT 9:18 AM
