1964 Ford Galaxie Ignition switch
45,000 MILES • V8 • 2WD • AUTOMATIC
THEP18
My switch fell apart. Dont know how to remove cylinder from dash. any advise?
May 26, 2010 at 9:18 AM
HMAC300
  • 48,601 POSTS
on the switch part where the key goes you will see a tiny hole. put eh key in then put a paper clip in the hole and turn the key to accessory, push in and remove the key lock assy. then unscrew the escutcheon on the outside and replace the switch. reverse procedure for assembly. although you don't need the paper clip to install the key lock.
Jun 19, 2010 at 1:53 AM
