1964 Ford Galaxie cant get my engine to fire
1964 FORD GALAXIE
2,000 MILES • V8 • 2WD • MANUAL
BRADY527
my engine turns but it wont fire and all the wiring is good and i replaced the egnition coil, the destributer cap the rotor the spark plugs, and the spark plug cables......what do i do?
Aug 29, 2009 at 11:22 AM
Do you have spark? If not is it a contact point distributor-if so check the point gap.
Electronic type-check the distributor pick-up coil and ignition control module
Aug 29, 2009 at 11:38 AM
