1963 Ford Galaxie Leaks
1963 FORD GALAXIE
65,000 MILES • V8 • 2WD • MANUAL
BDPOIRIER
Greetings, Guys;
I replaced EVERYTHING when I replaced the brake system, even the wheel bearings while I was there. The new brakse lines, "factory replacement" from a Galaxie specialist, leak at almost every fitting; at the wheel cylinders, the rubber flex lines, "T" fittings at the rear differential and front frame rail.....
frustrating.
Is there a tread sealant I should try?
Thanks
Ben
Apr 7, 2010 at 7:00 PM
HMAC300
  • 48,601 POSTS
absolutely DO NOT use any sealer on brake lines or fittings. If it leaks get a line wrench and make sure they are tight, not an open end wrench. Also check the flare as they may be ieitehr wrong or just a single flare. They shold be double flared... If they aren't that's why it leaks.
May 20, 2010 at 6:29 PM
