Ford Fusion has banging noise in right rear area.
FORD FUSION
AROSE50
This happens when going over small and large bumps in road. It sounds like a loose muffler, or a broken shock absorber(like on an older car). Any ideas on this? In trunk: jack, lug wrench, and spare tire are tightened down - rest of trunk area is empty.
Thank You - RAY
Apr 29, 2007 at 2:58 PM
BRUCE HUNT
  • 3,754 POSTS
Since it is front wheel drive that eliminates a few things. I is highly difficult to find some of these because sitting there is constant pressure on most of them. When they go airbourne so to speak things no longer have the pressure and they can make the noise as they settle back in to place. You have stated two obvious ones. There could be a stabilizer bar that is loose or a coil spring that is broken.
You might try jacking the car up and seeing if you can find anything loose under the car. Be careful!
Jun 21, 2007 at 6:04 AM
