2007 Ford Fusion REAR PISTONS WILL NOT DEPRESS BACK INTO CA
2007 FORD FUSION
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
GEORGEMOM
MEMBER
1 POST
rEPLACING REAR BRAKE PADS, CANNOT GET THE PISTON TO SET BACK INTO THE CALIPER HOUSINGS
Aug 20, 2009 at 2:39 PM
DAVE H
✓Experienced Mechanic
there is a special tool used to rotate the piston back into caliper .. most autoparts stores will be able to supply this
Sep 7, 2009 at 10:47 PM
