2007 Ford Fusion 100% total system loss
78,000 MILES • 4 CYL • 2WD • MANUAL
TDR4141
Had a very slight bump from behind on the highway at 60 MPH. It put me into a 360 spin for over 2 times and ended up going backwords at about 50 mph and I applied brakes to turn me around the right way and came to a stop with any damage except now nothing at all works. I mean nothing, What do I do
Apr 18, 2010 at 4:01 PM
  • 110,248 POSTS
You need to start at the power source. Check to make sure nothing was disconnected or damaged at the battery. Also, check the fuses under the hood to make sure you didn't pop one of the main fuses.
Oct 21, 2010 at 1:55 AM
