2007 Ford Fusion
2007 FORD FUSION
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
CARLATIO1973
I started my Ford Fusion this morning. As I was pulling out, my steering wheel wouldn't turn...then the battery light went on....what is wrong with my car?
Sep 4, 2010 at 9:37 AM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
Well, if the engine was still running when that happened, then you likely lost the drive belt. They don't fall off or break bu themselves so if that is the case, you will have to determine what caused it.
Sep 4, 2010 at 1:33 PM
