2006 Ford Fusion How to remove front brake rotors
29,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVE70-79
I need to take off my front rotors and have them turned. My question is how do they come off? Do they just slip off after you remove the caliper and pads or is it like my 2004 for truck... where you have to remove bearings and races? Just trying to get a heads up.
Dave
Jul 9, 2008 at 4:32 AM
DAVE70-79
Well I tore it apart not knowing. I can tell anyone else that may want to know that you must remove the caliper (two 14 mm bolts), pad housing (two 15 mm bolts) , and the two T40 bolts on the front of the rotor. Thats all there is to it. You may have to give it a small tap with a rubber mallet to get it free.
Dave
Mar 16, 2021 at 11:01 AM
