2006 Ford Fusion hard pedal
2006 FORD FUSION
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
ENDUSERGUY
just replaced front brake pads on my car and the car was fine for about 15 miles and now I have a hard pedal. I looked at the brake booster to see if it had a leak and it was fine with enough vacuum, but still have a problem with a hard pedal. I checked the front calipers and they slide. Need some help.
Oct 2, 2010 at 11:12 PM
  • 110,194 POSTS
Did you check the booster with a vacuum gauge to see if it holds vacuum?
Oct 21, 2010 at 7:29 AM
