2006 Ford Fusion front wheel bearings
2006 FORD FUSION
102,555 MILES • 4 CYL • 2WD • MANUAL
WHAMMER55
i just had my clutch repaired and a rebuilt transmission installed. the mechanic suggested i consider replacing the wheel bearings in front. is this a job i can do, or what would be a reasonable cost at a repair shop?
May 29, 2009 at 5:11 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model a S, SE, or SEL? Also please tell me your engine size in liter.
May 29, 2009 at 1:10 PM
WHAMMER55
2006 4 cyl manual trans SE
Jun 1, 2009 at 1:06 AM
IMPALASS
  • 3,112 POSTS
Hello - You need some special tools to remove the bearing. It needs to be pressed out and in. Now you could remove the hub and take it somewhere and see if they would press the bearing out and in, but it may be less work/time/expense just to have them do the entire task. Also you will need pullers etc to remove the ball joints etc from the wheel knuckle.
https://images.2carpros.com/forum/automotive_pictures/248015_f59_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Estimator_2.jpg
I attached a rough estimate for labor only.....I did not have the cost of the bearings. Hope this helps.
Jun 1, 2009 at 2:34 PM
