2004 Ford Fusion Windscreen washer
2004 FORD FUSION
MARK DAVIES
Electrical problem
2004 Ford Fusion 40000 miles
My windscreen washer has stopped working, the back one still works but the front one does not.i have checked the hoses and the nozles and all are fine, i think it may be the button on the steering column. Can you suggest a way to fix it ?
Dec 11, 2008 at 6:44 PM
DAVE H
  • 13,384 POSTS
check your are getting power to the motor before you start taking steering column apart .. the button control's front and back .. take electrical plug off front washer motor ... use a voltmeter to check power supply .. if there is power the motor is bad .. replace motor ... let me know
Dec 11, 2008 at 9:10 PM
JNOVACK
  • 723 POSTS
Yes check for power at washer motor if no power check fuses and then as lastly then the switch
Dec 15, 2008 at 11:11 AM
