2002 Ford Fusion speedo and milage display
ONESEED
2002 Ford Fusion
hi,
i'm a new i have a problem with my fusion, the speedo stop working and no milage is being displayed, at first the speedo worked on and off, but both speedo and milage display does nothing.
i would appreciate if anyone could help. thanks in advance.
Nov 14, 2008 at 10:32 PM
DAVE H
  • 13,383 POSTS
check the wiring to the VSS .. (vehicle speed sensor) sounds like you may have a loose connection .. the fusion/fiesta was not released here in america ... i'm trying to locate a wiring diagram for you ?? all the instrument cluster is controlled by sensors connected to the PCM/ECU ..(computer) ..
Nov 14, 2008 at 11:02 PM
