2006 Ford Freestyle Engine Will Not Crank
74,000 MILES • 6 CYL • AWD • AUTOMATIC
P51
The engine will not crank. After being parked for approximately one hour the engine would make no noise at all when turning the key and the battery has a full charge.
Thanks,
Rob Larson
spitfire101@comcast.net
630-254-7006
Apr 11, 2010 at 12:43 PM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Apr 11, 2010 at 1:08 PM
