2006 Ford Freestyle changing wheell bearings
CHUBOLT
Drive Train Axles Bearings problem
2006 Ford Freestyle 6 cyl All Wheel Drive Automatic
when changing front wheel bearings should I change both sides? I ask this because I have changed the right side twice and it's makeing noise again.
Jan 24, 2010 at 9:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
no its not necessary, seems like something else is at fault causing the bearings to fail prematurely. check for play in the ball joint for that specific side
Jan 24, 2010 at 10:04 AM
