2005 Ford Freestyle replace rear brakes
87,000 MILES • 6 CYL • AWD • AUTOMATIC
IMPOMO
How do you replace the rear brakes on this vehicle? Are there any step by step instructions you could give?
Jan 29, 2010 at 7:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Be certain to use part numbers 7F9Z-2200-A and 8G1Z-2001-A .. These are updated brake pad part numbers as the older style brake pads were wearing prematurely. For more details contact local Ford dealer.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1536.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_464.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_174.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname4_87.jpg
Jan 29, 2010 at 7:48 AM
BAHAMABEN
https://images.2carpros.com/forum/automotive_pictures/567964_IMG_1203_1.jpg
https://images.2carpros.com/forum/automotive_pictures/567964_IMG_1204_1.jpg
i have attached two pictures of the special tool. i bought it at Harbor Freight Tools for $39.99 on 8-31-2010. Please note in the second picture there are TWO T handles: one is for turning the caliper clockwise, the other for turning the caliper counterclockwise. Harbor Freight also sells a tool set that is in a red plastic box, but it only has the T handle that goes clockwise. On the 2005 model you need both T handles to get the job done. It is very simple to use and the replacement of the pads is very easy once you get the tool.
Sep 1, 2010 at 1:57 AM
