Interior problem
2005 Ford Freestyle 6 cyl All Wheel Drive Automatic
my driver side heated seat dont work switched module still dont work get power to connector what could it be?
Sunday, December 14th, 2008 AT 12:34 PM
DE772601
MEMBER
Hi well to help you out if you changed the control module for the switch and you have 12 volts to the control switch then you need to replace the switch at the seat, hope this will help you.
